mzbwlk
« on: April 14, 2007, 02:18:26 AM » |
I've had my Zune for a few months. I did the 80GB upgrade. I got board. I ripped it apart and installed 2 80GB Toshiba MK8009GAH hard drives  !!!! Yep!! 160GB in a Zune. I can go back and forth between them with a switch on the side. I'm in the process of making up some PCB boards to make it easer to install. Here is a link to see a video of it. http://www.youtube.com/watch?v=xHPcwhgzxloIf anyone is interested let me know.
Zebes
« Reply #1 on: April 14, 2007, 04:17:02 AM » |
great work, too bad both drives couldn't fit in the case, you made it look rather nice though +10
Zebes Mods Xbox Mod Service
Kaiser
« Reply #2 on: April 14, 2007, 11:50:44 AM » |
nice, and I like how you managed to integrate that second drive. I guess since only one drive is working at any given time it doesn't get lower playtimes.
 "Voil? ! In view, a humble vaudevillian veteran, cast vicariously as both victim and villain by the vicissitudes of Fate. This visage, no mere veneer of vanity, is a vestige of the vox populi, now vacant, vanished. However, this valorous visitation of a by-gone vexation, stands vivified and has vowed to vanquish these venal and virulent vermin van-guarding vice and vouchsafing the violently vicious and voracious violation of volition." ~ V
MAC KING P+Kr3w
« Reply #3 on: April 14, 2007, 12:36:15 PM » |
that is very nice
iMac 24"-2.4ghz-500gb-Leopard-4gb RAM Macbook Air- 2.8ghz-64gb SSD-2gb RAM Macbook Pro 17"-2.4ghz-250gb-Leopard-2gb RAM Xbox 360 & WiiiPhone 8gb I AM THE MAC KING!
~+-{|Tim|}-+~
« Reply #4 on: April 14, 2007, 12:43:57 PM » |
OMFG- amazing! Can you tkae some pics of the inside to show us how you managed it?
RSX WHEEEEEEEEE
« Reply #5 on: April 14, 2007, 01:11:10 PM » |
lol its like 2 zunes in one. beast.
mzbwlk
« Reply #6 on: April 14, 2007, 01:20:12 PM » |
Here are some pics...
mzbwlk
« Reply #7 on: April 14, 2007, 01:24:09 PM » |
And these....
mzbwlk
« Reply #8 on: April 14, 2007, 01:42:07 PM » |
As you can see I had to modify the cables and the hard drives to get this thing to work. That is why I'm making a jumper board to do this. There will be no need to modify (cut or re-solder) any cables or hard drives. Just connect the zune HD cable to the board and the board to the 2 hard drives. These boards should be done next week!!!!!
Hrshycro
« Reply #9 on: April 14, 2007, 08:21:03 PM » |
yeah...well i like mine untouched...30 gbs is all i need!
Samsung P2 = <3 Awesome!  Sig Approved by Global Mod
mzbwlk
« Reply #10 on: April 14, 2007, 08:52:04 PM » |
Good for you!
CardinalSin
« Reply #11 on: April 14, 2007, 09:58:42 PM » |
its too bad my single 80 gig didn't work, just glitched and wouldn't move unless casing was off.
mzbwlk
« Reply #12 on: April 14, 2007, 11:21:12 PM » |
Try checking your cable to the hard drive. Make sure the contacts on the cable line up with the pins on the hard drive. Heres a picture looking at the end of the hard drive. Take a look (maybe with a Magnifying Glass) to make sure their lined up.
dragonforce
« Reply #13 on: April 15, 2007, 09:10:58 AM » |
that is awesome +10
Never Argue with an idiot, they will drag you down to their level and beat you with experience.
Soysauce777
« Reply #14 on: April 16, 2007, 06:48:25 PM » |
Nice! I dunno if it would be possible, but if I had the those kinda modding skills, I'd make it so the hd is somewhat detachable and make a lid or w/e. That way it would be so bulky.  But still, nice job.
"It was the best of times, It was the worse of times; it was the start of the times" Zune 30 - First Gen Proud owner of the first Zune
mzbwlk
« Reply #15 on: April 16, 2007, 07:11:55 PM » |
Thanks. Yeah, I thought about that too. The problem is the cable for the hard drive. It is only .20 mm (1/125") thick. You can't really keep plugging it in and out. As for the case, I just threw it together. It's about 8mm (1/3") thicker than the origional. I am making some boards PCB so there will be no need for soldering or anything like that. I'm also looking into making a new back half of the plastic case.
1loudsvt
« Reply #16 on: April 16, 2007, 07:50:13 PM » |
hmmm i would be interested in the board...keep us posted
nate_aight
« Reply #17 on: April 16, 2007, 08:54:49 PM » |
thats sweet could hold a lot of movies =) but 30gb is enough for me ive only used like 11gb -_-
