May 18, 2013, 03:13:19 PM
Author Topic: Headphones...  (Read 1536 times)
djmetsandy
Gadget Geek
What my country can't get...I want!:-)
« on: October 18, 2006, 05:09:36 PM »
I watched an interview last night on the zune and heard that the headphones are used as the antena for the radio..same as a sony ericsson phone..(dnt no about other phones as i stay to SE)..now my point is does that mean you can't use your own headphones?
If my links do not work then check there is not another http:// infront of the link i.e http://http://www.zunescene.com this is because zunescene forums adds it on auto when I copy/paste!
Blitzkrieg
pɭɹoʍ oɭɭəɥ
.: Blitzkrieg :.
« Reply #1 on: October 18, 2006, 07:58:03 PM »
No you can use your headphones and anything does a good antenna... As far as there is metal in it (any wire will do the job)... It's just physics  Grin
I can imagine a perfect world, a world without hate, a world without war. Then, I can imagine us attacking that world because they'd never expect it!
·٠●•۩۞۩[̲̅B̲̅o̲̅O̲̅m̲̅(ٿ)̲̅H̲̅e̲̅a̲̅d̲̅S̲̅h̲̅o̲̅t̲̅]۩۞۩•●٠·
djmetsandy
Gadget Geek
« Reply #2 on: October 19, 2006, 08:36:26 AM »
That is true I know but SE phones have to have the special adapter first...which we all know Zune will not have on the release and that is why i'm wondering whether you have to use MS headphones in order to use the radio...
understand? Huh?
Blitzkrieg
pɭɹoʍ oɭɭəɥ
.: Blitzkrieg :.
« Reply #3 on: October 19, 2006, 04:07:02 PM »
I think the Headphones plug should be the standard 1/8" size...
djmetsandy
Gadget Geek
« Reply #4 on: October 19, 2006, 04:32:45 PM »
we'll just wait and c! but i think it is just a normal headphone port too!
Zunetastic
Gadget Geek
« Reply #5 on: October 19, 2006, 06:12:23 PM »
I almost garuantee that the headphone port will be 1/8 inch or the same size as the ipods. Also I also believe that the headphones are used as an antena, but if you use you own headphones everything will work exactly the same... It might just have a little slammer linking range.
djmetsandy
Gadget Geek
« Reply #6 on: November 08, 2006, 07:31:02 AM »
dont no why im so interested in the radio but owell! lol
Page created in 0.102 seconds with 21 queries.
