May 19, 2013, 06:27:09 AM
Author Topic: will it work with anything under...  (Read 979 times)
AVA
All you have to do is shout it out!
« on: November 14, 2006, 11:49:21 PM »
will the zune be reconized by any usb under a 2.0 i dont know what i have but its not a 2.0 will a zune sttill work? thank you!
Shocked Voted Favorite moderator of 2006Shocked
PSN ID: Mattie805
ZuneScene's resident Apple Employee
AVA
« Reply #1 on: November 15, 2006, 10:11:43 AM »
bump....
PSN ID: Mattie805
AVA
« Reply #2 on: November 15, 2006, 07:08:47 PM »
bump again....
PSN ID: Mattie805
Kayo
Life's Too Short ...Take No Prisoners !!!
« Reply #3 on: November 15, 2006, 07:12:33 PM »
No it wont be recognized as a USB drive.   Only the the Zune software will recognize it.  The thing is not configured as a storage media therefore usb won't recognize it.
A software change to the Zune may be down the road which will allow it to be recognized as a storage drive as well.
AVA
« Reply #4 on: November 15, 2006, 07:29:39 PM »
no i mean, i have several USB ports on my computer. But none of them are 2.0 only 1.something....will it still work...ipods still worked.
PSN ID: Mattie805
versus257
« Reply #5 on: November 16, 2006, 01:28:56 AM »
It will not work. I tried using a USB 2.0 adapter that connects to my USB 1.0 port and that somehow destroyed the battery of the Zune I owned. So I had to get a new one.
You definitely need to use USB 2.0. Zune won't accept anything less. Zune is turning out to be a real prissy canine.
AVA
« Reply #6 on: November 16, 2006, 10:04:10 AM »
darn, where can i get one? does it have to be installed? or just slapped on? how much does it cost??
« Last Edit: November 16, 2006, 10:07:49 AM by AvA » Logged
PSN ID: Mattie805
versus257
« Reply #7 on: November 16, 2006, 10:42:59 AM »
The adapters come in all shapes and sizes, ranging from $5 to $30+. The more expensive the adapter, the more ports generally. You also pay for brand name as price goes up, not necessarily quality. You can buy the adapters in stores that sell computers. Best Buy, Circuit City, hell even Wal-Mart probably has them. Wal-Mart has everything.
You install the adapter inside the tower, like a video card or something. It should come with instructions and it shouldn't be that complicated/hard to find instructions for inserting into the computer on the internet.
AVA
« Reply #8 on: November 16, 2006, 10:44:15 AM »
thanks....darnnn now i have to get one of these now!!! Angry Angry
PSN ID: Mattie805
AVA
« Reply #9 on: November 16, 2006, 05:39:56 PM »
So if i go to a computer store, is it something i have to open up my computer to put in...if so...i probly cant get a zune  Cry my mom would never let me do that...
PSN ID: Mattie805
Page created in 0.146 seconds with 21 queries.
