May 22, 2013, 08:31:10 AM
Pages: 1 2 [3] 4   Go Down
Author Topic: Ok. I'd like to downgrade now...  (Read 7629 times)
Eternalodyssey
Gadget Geek
I'll take my Zune Black with no sugar
« Reply #36 on: November 13, 2007, 10:21:25 AM »
Is it me or does it seem like the movies I had in the native .wmv format are taking forever to sync???
Zune Gen1
100 Gb Hard Drive
850 Mah Battery
External Hard Drive mod
Extremely small wang
skoprowski
« Reply #37 on: November 13, 2007, 10:23:06 AM »
Well...I upgraded this morning and two things stick out to me:
1) the new firmware seems to be slower then 1.4- the transitions between menus seem a lot slower
2) I don't like the fact you have to import music into your library before you can sync it to your zune.  Before I could just drag files from anywhere on the computer or cd, usb drive etc.  Now it appears you have to drag the files to your library first and then sync to the Zune.
slaughters
« Reply #38 on: November 13, 2007, 10:25:17 AM »
I've not upgraded the firmware yet, but it could be that the files were in wmv format, but of the incorrect resolution
"But, I am just following my dream !"
"My son, following your dream is not always wise or noble. Charles Manson was just following his dream too."
WillysJeepMan
« Reply #39 on: November 13, 2007, 10:28:32 AM »
I guess I just have to get used to it like I did the old one.
EXACTLY!
Um... hello?  It's not the same software!  Of course it's going to be DIFFERENT!
Get used to it.
A buncha whiners in this thread.
It's pretty sad that you do not have the discernment to differentiate between good change and bad change.  There are some changes to the new software that are just flat out bad.
WillysJeepMan
« Reply #40 on: November 13, 2007, 10:32:35 AM »
My Zune-optimized .wmv files (320x240) sync as quickly as they did under the older software.
Yes... syncing is now slower.  Sad
linoleum
« Reply #41 on: November 13, 2007, 10:40:46 AM »
hmm.. I love it.  It feels fresh and new... like a shiny new car.  No hiccups with the software [on my work and home laptops], firmware updated very fast.  Kudos to MS for such a great job.  PLUS I got to keep my preset EQs.
How do I find the Camo background?
R.
thebudman
Gadget Geek
WWW
« Reply #42 on: November 13, 2007, 10:43:22 AM »
Anybody have a solution for the TV Shows video section being messed up?  Issue is that on 1.4 you would use an external meta data editor to change the video type to TV Show and then the videos had two specific meta data tags, video title and episode title.  If i was importing, say .Hack//SIGN anime i would apply the title ".Hack//SIGN" to the video title for all the videos i'm wanting to import and sync to my zune.  Then I set the appropriate episode data for each episode.  This way, when I view the TV Shows directory on my zune, the videos would say .Hack//SIGN and under it in smaller text say "27 episodes".  You click inside it and it shows you all 27 episodes.
On the new firmware, it doesn't do this at all.  It just lists all the episodes out as loose videos.  When I label episodes I label them in order by appending 01, 02, 03 to the beginning of each episode name.  So if I have 5 seasons of different shows, all the first episodes from every tv show shows up together instead of being a folder with the show title.
ARGH!!!  Anybody know of a way to fix this?  I haven't tried resyncing my videos yet as I was doing this before I left for work.
Last.FM Weekly Top Artists
Online Profile/Blog
Last.FM
waxc3
Uber Nerd
« Reply #43 on: November 13, 2007, 10:44:30 AM »
i am never going to update mine again. i am avoiding this update.
i need my 5 star and my auto playlists!
Ricardo Dawkins
WWW
« Reply #44 on: November 13, 2007, 10:54:37 AM »
I bet a few of you didn't remove the previous software and performed an update. >shakes head<
Samsung Galaxy S (Vibrant) + Black Zune 80 + MEElectronics Ai-M6 Clear + Zune Premium + AKG K26p + JVC HA-FX66 Blue -Air Cushion-
 Zune 30 (sold) - Tado Zune 80 (lost/stolen)
Synapse
Neural Circuitry
« Reply #45 on: November 13, 2007, 11:04:16 AM »
I personally really like the new rating system, much less though time consuming as I used to take a lot of time with my ratings.
slaughters
« Reply #46 on: November 13, 2007, 12:55:34 PM »
Well - since I did this from the provided "Check for Updates" option in the Zune software then - No.
This also has absolutely nothing to do with the meta-tag mis-labeling of audio files, or the re-architecture of the video section to essentially ignore all meta-tag information. (Both of these together seem to be about 90% of the issues that people are having)
cellocello
« Reply #47 on: November 13, 2007, 12:58:00 PM »
For those with library issues:
http://forums.zune.net/549/ShowPost.aspx
XBOX Live - gemeric
WillysJeepMan
« Reply #48 on: November 13, 2007, 01:03:02 PM »
Yep... that's the procedure to "nuke" the library database.  Unfortunately it isn't a simple matter of a corrupted database (which is what I initially suspected) but an issue of the Zune software incorrectly interpreting and adding albums to the library.
That fix isn't going to help.
cellocello
« Reply #49 on: November 13, 2007, 01:05:29 PM »
I'm working through the mess myself ... and, for my particular case, this workaround helped quite a bit.
This + mp3tag + my own diligence = approaching a clean library
YMMV
XBOX Live - gemeric
Kaiser
Admiral
Trust in the Bazooka Fox!
WWW
« Reply #50 on: November 13, 2007, 01:06:31 PM »
Never should anyone have to do this.
I wanna ask about your meat lovers' pizza. I like meat, but I'm not sure if I'm ready to love again.
Dani_92
Master Chief
Proud to be Canadian
« Reply #51 on: November 13, 2007, 01:07:48 PM »
honestly the new update is kind of tickin my clock off but ill take time to get used to it , just like the older version. I just can't get the wifi sycing working yet. Good luck with all you guys peace from canada
D
g52
Gadget Geek
« Reply #52 on: November 13, 2007, 01:08:07 PM »
" I'll like to downgrade now ".
Topic creator needs to be shot for poor use of grammar.
bcon
« Reply #53 on: November 13, 2007, 01:08:52 PM »
chill
Pages: 1 2 [3] 4   Go Up
Page created in 0.217 seconds with 21 queries.
