February 09, 2010, 02:22:59 AM
Pages: [1] 2 3 ... 21   Go Down
Author Topic: Unofficial Procedure to downgrade from 2.x -> 1.4  (Read 53453 times)
WillysJeepMan
« on: November 14, 2007, 12:14:15 AM »
« Last Edit: February 05, 2008, 04:48:24 PM by WillysJeepMan » Logged
purplepills
Ruler of Zunes
It's like sex, except I'm having it
« Reply #1 on: November 14, 2007, 12:15:10 AM »
bleh
onthegreenrb
« Reply #2 on: November 14, 2007, 12:15:47 AM »
Can I get a link to do the same?
ZuneLover2.0
Oh you mad cuz i'm stylin on you!
« Reply #3 on: November 14, 2007, 12:16:48 AM »
smh
Amblin
« Reply #4 on: November 14, 2007, 12:18:36 AM »
Might I ask, why would you do such a thing? Huh?
WillysJeepMan
« Reply #5 on: November 14, 2007, 12:20:32 AM »
If you have to ask then you haven't spent much time with both levels of software/firmware.  The 2.2 firmware overly compressed album art, changed the way it displayed picture thumbnails, Playskool sized menu font, etc.  The 2.2 desktop software removed a lot of functionality... including increasing sync time of video by 33%.
onthegreenrb
« Reply #6 on: November 14, 2007, 12:24:37 AM »
Where's the instructions for the downgrade? This album art pixelation is frustrating.
I really loved 1.4 Sad
purplepills
Ruler of Zunes
« Reply #7 on: November 14, 2007, 12:24:57 AM »
i like the new software much better
ps249
« Reply #8 on: November 14, 2007, 12:26:47 AM »
why dont you spend some $$$$$ and get a better computer then.
"Victim of the December 31st 2008 Zune 30 Meltdown!"
WillysJeepMan
« Reply #9 on: November 14, 2007, 12:35:57 AM »
If you are so happy with the latest firmware and software why not avoid this thread?  I know that there are quite a few others who want to know this information.
geekbeats
« Reply #10 on: November 14, 2007, 12:36:23 AM »
I dont get why youre having these problems?
All my cover art looks exactly the same as it did before, actually it looks a little better because now the bottom edge is no longer obstructed by the position bar.
I converted/synced some movies and they took the same amount of time as they did with the old software.
What are the specs on the computer youre using?
xkalibur
« Reply #11 on: November 14, 2007, 12:36:28 AM »
so how are you going to use zune pass ?
and no podcasts will suck
WillysJeepMan
« Reply #12 on: November 14, 2007, 12:39:06 AM »
Then be happy.  I'm not trying to convince you that you should downgrade... and I certainly don't need convincing to upgrade (again).
WillysJeepMan
« Reply #13 on: November 14, 2007, 12:39:42 AM »
I don't use Zune Pass.   I can handle podcasts with the old software/firmware just fine, thank you.   Grin
Kaiser
Master of the Zuniverse
Hate You Can Trust
« Reply #14 on: November 14, 2007, 12:42:20 AM »
The desktop software seems to be working just fine for me, though my library on that thing is scant, as I have Windows stuffed into a 5GB partition, so I haven't encountered library issues. The interface looks OK, though the Playskool font on the main menu is senselessly huge. The only issues I've run into so far is that it will stall for a few seconds, almost consistently, when I enter the music folder, and the videos I had loaded on it now refuse to play properly. They stall for quite a while. I've given up trying to use them.
"Voil? ! In view, a humble vaudevillian veteran, cast vicariously as both victim and villain by the vicissitudes of Fate. This visage, no mere veneer of vanity, is a vestige of the vox populi, now vacant, vanished. However, this valorous visitation of a by-gone vexation, stands vivified and has vowed to vanquish these venal and virulent vermin van-guarding vice and vouchsafing the violently vicious and voracious violation of volition." ~ V
DarkS2K
A Proud G1 Android owner.
« Reply #15 on: November 14, 2007, 12:44:24 AM »
I don't get it   The zune firmware is AWESOME.
Its just the pc software that is so-so.  Why would you downgrade the zune?
JaredMarino
« Reply #16 on: November 14, 2007, 12:45:11 AM »
Hey man, dig this...
If you want to be a cool hip cat
the Zune 2.2 is where it's at, y'dig? Grin
Kaiser
Hate You Can Trust
« Reply #17 on: November 14, 2007, 12:45:50 AM »
Well I'm certainly considering downgrading and I've only been using it for maybe 15 minutes. The stalling gets quite annoying, and with the complete lack of proper video playback there's little reason to keep it this way. Usability has dropped dramatically.
Pages: [1] 2 3 ... 21   Go Up
Page created in 0.166 seconds with 21 queries.
