lpxxfaintxx
« on: January 21, 2008, 03:22:31 PM » |
PityOnU, a respected member at ZuneBoards: Finally, a release candidate of zAlternator is here! Yay! zAlternator is a program that will allow the Zune to be picked up and synced with programs other than the Zune program. It has been fully tested and proven to allow the Zune to be picked up and synced with the Zune program (duh), Windows Media Player 11, Winamp, and MediaMonkey. I have been unable to fully test the iTunes side of the program, but hopefully it should work. More info here.
Unknown123
« Reply #1 on: January 21, 2008, 04:05:38 PM » |
looks cool... not 100% sure about downloading it...
Machiventa
« Reply #2 on: January 21, 2008, 04:58:23 PM » |
wow this just might be what alot of people are looking for.
i'm off to test it!
thanks!
WillysJeepMan
Offline
« Reply #3 on: January 21, 2008, 05:00:59 PM » |
i'm off to test it!
thanks!
It doesn't eliminate the need for the new Zune software. You have to start the Zune software and kill it every time you want to sync. With that caveat in mind, I'm sure that it will be beneficial to many.
Machiventa
« Reply #4 on: January 21, 2008, 05:13:58 PM » |
haha i just read that too.
« Last Edit: January 21, 2008, 08:46:34 PM by Machiventa »
FederalBmx
« Reply #5 on: January 21, 2008, 05:45:27 PM » |
houston we have another breakthrough over.
Machiventa
« Reply #7 on: January 21, 2008, 05:59:37 PM » |
wow just tried this and can confirm it works (for me) with mediamonkey. and the cool thing is that i only had to kill the sync process on the zune software once. i thought you had to do it each time you wanted to sync with another program. this is sweet! the first thing i tried was syncing from MM and it worked perfect. the next thing i tried and this makes me very happy is editing the tags on the device and it worked!! now i'm gonna test making a playlist from media on the device. alot of the music i put on my zune i've deleted from my pc and it's impossible to create a playlist on the zune software (without having to copy to my collection of which i have no HD space to do so). if i can do that then i'm sold.
WillysJeepMan
Offline
« Reply #8 on: January 21, 2008, 06:14:33 PM » |
Reboot your system, or try to run the Zune software again and let us know what happens.
Machiventa
« Reply #9 on: January 21, 2008, 06:15:44 PM » |
^^ i have! and all you have to do is run zalternator again and choose the zune SW
WillysJeepMan
Offline
« Reply #10 on: January 21, 2008, 06:38:24 PM » |
Excellent. I just tried it multiple times with MediaMonkey. Seems to work but because MM only does music, it isn't useful for me. WMP10 synced great on one system. I'm going to try on my main system.
Machiventa
« Reply #11 on: January 21, 2008, 06:55:18 PM » |
rebooting doesn't "clear" the sync settings. after a reboot i opened MM and there was my zune.
and there's tons of add-ons for MM such as video support.
bcon
« Reply #13 on: January 21, 2008, 07:29:51 PM » |
tell us how it works
btw .. props to ZB for this
Machiventa
« Reply #14 on: January 21, 2008, 07:43:46 PM » |
no sense in having two threads about this.
bcon
« Reply #15 on: January 21, 2008, 07:46:20 PM » |
first on i read about it
but if you can link me the other one i can merge them
Machiventa
« Reply #16 on: January 21, 2008, 07:50:11 PM » |
SteveBIRK
« Reply #17 on: January 21, 2008, 07:54:33 PM » |
damn i thought i was the first one
ARE YOU HAPPY NOW!!!!!!
