February 09, 2010, 06:33:04 AM
Pages: [1] 2 3 ... 17   Go Down
Author Topic: Patcher to make your zune an External Hard Drive  (Read 92151 times)
Berdon
« on: November 24, 2006, 03:10:04 PM »
Patcher 2.0 is complete.
Click here to download
Requirements:
  • Windows XP
  • .NET Framework 2.0
  • A Zune
Instructions:
  • Unplug your Zune.
  • Turn off the Zune Software.
  • Run the patch.
  • Plug in your Zune.
Did it work?
  • If it said "Patched successfully", it worked.
  • Goto "My Computer" and double click on your Zune then on storage, and viola.
  • Don't worry about there being two icons, it's normal. Both work, click the one you like best.
What now?
  • Note: To view any files this way, you must have the Zune software running. To create or modify files, you must have the
    software running and "Syncing".
  • Also Note: Once you have began copying a file (not sure about multiple files) to your Zune, you can stop the syncing and close the Zune software. The transfer will still continue and finish
  • Make a folder and start dropping stuff in it.
  • Email yourself the link to the patcher so if you plug it in on any other computer you'll have access to it. (The link is better then the actual file, as as more info becomes available, newer versions will be available and always as the same name, so you can always just go back and re-download from the very same link)
What if it doesn't work?
  • Open regedit
  • Go to the location specified in the tutorial
  • Take a screen shot (hit the print screen button near the top right corner of your keyboard)
  • Open mspaint (start->run->type in mspaint and hit enter)
  • Paste the screen shot (hit ctrl+v)
  • Save it as a .jpg or something small (not a .bmp)
  • Email me the picture (berdon(DOT)zune(AT)gmail(DOT)com)
About:
  • Utilizes the Registry mod (from www.ZuneBoards.com), created for people that don't want to fiddle around in their registry.
« Last Edit: November 27, 2006, 03:14:17 PM by Berdon » Logged
~+-{|Tim|}-+~
Cover Me- 9.28.07
« Reply #1 on: November 24, 2006, 03:29:23 PM »
You rock.
CardinalSin
woot 4 anime
« Reply #2 on: November 24, 2006, 03:35:43 PM »
have it on my vista but dunno about my xp its kinda screwed so i never know what oim gunna get but it does have 2.0 which i had to seperatly dl from m$ update to get to install. Maybe when vistas been out for a few months what ill do is get a xp media cneter edition off the tornados get a hack and install on this partition and re-install vista on my bigger one, though i prob should say this on these forums.
~+-{|Tim|}-+~
Cover Me- 9.28.07
« Reply #3 on: November 24, 2006, 03:53:11 PM »
What?
Lloyd Christmas
« Reply #4 on: November 24, 2006, 04:50:14 PM »
This is excellent! Thanks.
CardinalSin
woot 4 anime
« Reply #5 on: November 25, 2006, 12:39:46 AM »
how can you tell if the patch has worked if you don't have a zune? i start it up and click patch, but nothing happens.
Berdon
« Reply #6 on: November 25, 2006, 01:19:26 AM »
Means it didn't work, you need a Zune for windows to create the registry entries.
dweezil
« Reply #7 on: November 25, 2006, 02:49:03 AM »
Followed the instructions - didn't work or me :-(
I even did the manual reg hack and it still doesn't list the zune, any ideas?
JuVy-C
« Reply #8 on: November 25, 2006, 09:49:38 PM »
Same thing, ive been trying everything for a couple hours. Do you need to format your zune, and for this hack to work do you have to have usb 2.0 ports? I cant think of anything else.
Berdon
« Reply #9 on: November 26, 2006, 09:22:56 AM »
Hmm, it should work flawlessly.
For anyone that it's not working for, could you:
1. Open regedit
2. Go to the location specified in the tutorial
3. Take a screen shot (hit the print screen button near the top right corner of your keyboard)
4. Open mspaint (start->run->type in mspaint and hit enter)
5. Paste the screen shot (hit ctrl+v)
6. Save it as a .jpg or something small (not a .bmp)
7. Post it here (you'll need to upload it to somewhere too)
Alternatively, you could email me the picture (berdon(AT)gmail(DOT)com).
Berdon
« Reply #10 on: November 26, 2006, 12:29:21 PM »
New version up, should fix all the problems seen so far.
zylos
Zune Much?
« Reply #11 on: November 26, 2006, 01:59:42 PM »
Just got my zune today, thnx for the patch worked flawlessly.
so uh yea?
leo5111
« Reply #12 on: November 26, 2006, 03:33:08 PM »
ok i just did, said applied patch succesfully, how to tell if it realy worked?? Tongue
Berdon
« Reply #13 on: November 26, 2006, 04:21:07 PM »
To see if it worked, plug in your Zune and go to my computer. You should see your Zune listed there. You can then double click it, then double click on storage, and then traverse where ever you want.
leo5111
« Reply #14 on: November 26, 2006, 04:30:32 PM »
ok it worked thanx so should i make folder for stuff i put on it?  Tongue EDIT i see my zune device named leo there but i see another thing called leo right above it??
« Last Edit: November 26, 2006, 04:34:57 PM by leo5111 » Logged
Berdon
« Reply #15 on: November 26, 2006, 04:35:38 PM »
Yeah.
As of now, I'm pretty sure the stock firmware will just ignore all unsupported formats; however, it's probably best if you just make your own folder for your stuff.
leo5111
« Reply #16 on: November 26, 2006, 04:38:32 PM »
ok why is it makin 2 things i can click to get in the zune?? 1 has zune icon 1 does not??
Berdon
« Reply #17 on: November 26, 2006, 04:40:02 PM »
This is an interesting "feature" that hasn't been resolved completely yet. For now, just always click on the one with the icon (although, the other one works as well).
Pages: [1] 2 3 ... 17   Go Up
Page created in 0.133 seconds with 23 queries.
