May 21, 2013, 01:41:01 AM
Author Topic: Zune 80 Froze and then deleted all files  (Read 2905 times)
3L3M3NT
« on: July 05, 2008, 03:04:06 AM »
Alright here's the story.
I was using my Zune with the new Kicker ZK500, which FYI kicks ass.......... ok on with the story.  I was at our shop detailing our Jet skis and I had the ZK500 in a safe place to not get it wet or dirty , which was about 25 feet away and all of the sudden I have no music playing, so figured it was a track that had some dead time in it, so I go over to change to the next song and realize that the Zune is frozen.  Me not knowing how to reset it holds every combination imaginable and finally I got it to work after about a couple of hours.  I go to my music and there isn't a single file in there....... along with every other category.
So here is my question what did I do that would have caused me to erase everything off my Zune and yes I did search before making the post as now I know how to reset my Zune 80 thanks to this post---->http://www.zunescene.mobi/forums/index.php?topic=31119.0
Knowing that, what is a hard reset?
Is there any other info I should know about next time my Zune decides to freeze up on me?
Thanks in advance for any help Grin
« Last Edit: July 05, 2008, 03:28:21 AM by 3L3M3NT » Logged
Cozz
Uber Nerd
« Reply #1 on: July 05, 2008, 06:45:53 AM »
Chances are you did a hard reset which means complete format. As to why it froze, don't know. Maybe battery life or something
Anime is a Zunescene mod. He has lied about me and will not admit when he's wrong. I will probably be banned again for speaking the truth.
UPDATE: I have been banned. Nathan please help!
3L3M3NT
« Reply #2 on: July 06, 2008, 01:50:37 AM »
It had a fresh charge and when it's docked in the Kicker ZK500 it's charging as well.
My question is what will I need to do now?  Can I just plug in my Zune and it will sync or will I have to go through everything again and upload V2.5 and all that fun stuff?
Will my computer even recognize my Zune?
cs188
Zuner For Life
WWW
« Reply #3 on: July 06, 2008, 02:34:06 AM »
It will most likely do both - it will load on the newest firmware (2.5) first, and then sync all your content back. Smiley  The computer should recognize the Zune device correctly.
3L3M3NT
« Reply #4 on: July 06, 2008, 11:55:13 PM »
Thanks for the help.  I'll let you know how it goes.
3L3M3NT
« Reply #5 on: July 07, 2008, 05:47:22 PM »
Ok so I tried to sync my Zune 80 and it will get 3% into the sync and will give me the error code C00D124D.
What can I do to eliminate this issue?  Do I need to reinstall the Zune software?  Clear the hard drive on the Zune itself?
I'm getting a little frustrated, since I just purchased the Kicker ZK500 and can't use it, because my Zune if giving me problems.
The sync groups have already been deleted from the computer, so I have not problem clearing everything and starting over.  I just need to know how to do it.
So please help me so I can get to using my zune again. Cry
Death DealerV69
« Reply #6 on: August 06, 2008, 01:34:44 AM »
i have the same problem.
mine just deleted everything off the zune while listening to it.
ray_1883
« Reply #7 on: August 14, 2008, 12:43:32 AM »
i have the same problem, what i do is .... do a hard reset, re-sync zune and use the aux cable to play the zune. Yes you cant use the remote but at least you can use your kicker :p
Also i emailed kicker and they already know about the problem ... ill let you guys know.
3L3M3NT
« Reply #8 on: August 14, 2008, 02:12:24 AM »
Well I just got my new 80gb Zune, since they apparently couldn't fix my other one, or maybe it's just easier/quicker to mail out a new one..........
Anyways I was using my Zune and as I busy putting the last coat of varnish on the coffee table I built for my woods class this spring and I noticed some dead air time and of course the Zune is froze Angry
So I did a soft reset and looked under music and guess what.......... there wasn't a single song or file on the zune or atleast one that showed up, so I went inside to resync my Zune and as it's syncing it's telling me I don't have enough space on my Zune(I did have 77.66 gb of music on it)
I'm about to do a hard reset and see what happens.  I'll report back when I have done the hard reset and tried to sync my zune.
Ricardo Dawkins
WWW
« Reply #9 on: August 14, 2008, 11:35:39 AM »
did you use the Kicker unit with it again ?
Samsung Galaxy S (Vibrant) + Black Zune 80 + MEElectronics Ai-M6 Clear + Zune Premium + AKG K26p + JVC HA-FX66 Blue -Air Cushion-
 Zune 30 (sold) - Tado Zune 80 (lost/stolen)
3L3M3NT
« Reply #10 on: August 14, 2008, 12:31:04 PM »
Yeah I was using the Kicker unit, when it decided to freeze up and not recognize any of the files on there.  Since when I went to sync my Zune it told me I did have enough space on m Zune.
So I did a reset that wipes just the files, not the firmware and I was able to re-sync everything and it looks like I'll just be using the Aux in on the Kicker unit, till they get the issue resolved.
Kicker Tech
ZK500 with LOCOMX.com skin
« Reply #11 on: August 21, 2008, 05:59:16 PM »
Dear Fellow Zune Lovers,
I have heard of customers who are experiencing this problem. I apologize for the inconveniences this problem has given you, and I feel bad.
We are trying to pinpoint the root of the problem and identify a solution.
I invite anyone who has experienced this problem with their Zune device and ZK500 to send me a note via email ( HnP@kicker.com ) so we can connect and learn more about the circumstances surrounding your own Zune device and Kicker ZK500 problem.
Thank you,
Bryan
Product Line Manager @ KICKER HnP
Page created in 0.473 seconds with 21 queries.
