February 09, 2010, 06:38:45 AM
Poll
Question: Did MicroSoft's solution fix your Zune 30?
Yes - 115 (68.9%)
No - 45 (26.9%)
AngryMonkey's way worked for me. - 7 (4.2%)
Total Voters: 166
Pages: [1] 2 3 ... 66   Go Down
Author Topic: OFFICIAL ZUNE 30 FROZE THREAD  (Read 112002 times)
Bond007
« on: December 31, 2008, 02:36:06 AM »
This your administrator Unicron Social.
We know there is a big problem with the Zune30s. Please be patient and post here if you have any updates.
Zune Tech Support
1-877-GET-ZUNE (1-877-438-9863)
DO NOT OPEN YOU ZUNES AND DO A HARD RESET, IT DOES NOT WORK.
UPDATE 823PM
My Zune 30 is frozen. What should I do?
Follow these steps:
Disconnect your Zune from USB and AC power sources.
Because the player is frozen, its battery will drain?this is good. Wait until the battery is empty and the screen goes black. If the battery was fully charged, this might take a couple of hours.
Wait until after noon GMT on January 1, 2009 (that's 7 a.m. Eastern or 4 a.m. Pacific time).
Connect your Zune to either a USB port on the back or your computer or to AC power using the Zune AC Adapter and let it charge.
Once the battery has sufficient power, the player should start normally. No other action is required?you can go back to using your Zune!
My Zune 30 has been working fine today. Should I be worried?
Nope, your Zune is fine and will continue to work as long as you do not connect it to your computer before noon GMT on January 1, 2009 (7 a.m. Eastern or 4 a.m. Pacific time).
Note: If you connect your player to a computer before noon GMT on January 1, 2009,  you'll experience the freeze mentioned above?even if that computer does not have the Zune software installed. If this happens, follow the above steps.
What if I have rights-managed (DRM) content on my Zune?
Most likely, rights-managed content will not be affected by this issue. However, it's a good idea to sync your Zune with your computer once the freeze has been resolved, just to make sure your usage rights are up to date.
What if I took advice from the forums and reset my Zune by disconnecting the battery?
This is a bad idea and we do not recommend opening your Zune by yourself (for one thing, doing so will void your warranty). However, if you've already opened it, do one of the following:
Wait 24 hours from the time that you reset the Zune and then sync with your computer to refresh the usage rights; or
Delete the player's content using the Zune software (go to Settings, Device, Sync Options, Erase All Content), then re-sync it from your collection.
« Last Edit: December 31, 2008, 07:24:20 PM by Unicron Social » Logged
Gifted1
« Reply #1 on: December 31, 2008, 02:39:04 AM »
Wow, I just came here to see if I can find help for this because mines just got stuck on this screen too. I was plugging in my Zune to my computer so I can put music on it about 10 min ago. It's stuck on the Zune screen and I cant do anything. Can't reset it or anything. Is there anything I can do?
Sid3000
I like my Sprite Easter pink.
« Reply #2 on: December 31, 2008, 02:42:39 AM »
Make sure its charged. Mine was completely dead and I didnt know it, and everytime I tried to revive it it wouldnt respond.
15 min on the charger and it was good as new.
Gifted1
« Reply #3 on: December 31, 2008, 03:01:48 AM »
Mines was almost fully charged when I was looking at it a few hours ago so I doubt thats the problem. My screen is lit up with the Zune screen. It's just not responding.
I did a google search and some people said they just let the battery drain and then charge it and start it again and it will work so I will try that and hopefully it would work again.
Murderface
Proud owner of a Halo 3 Zune!
« Reply #4 on: December 31, 2008, 03:26:30 AM »
This is happening everywhere, guys.
DO NOT LINK IT TO THE COMPUTER!
I've heard unconfirmed reports of the software cleaning out itself due to this bug.
I have a Halo 3 30GB... I wanna cry. Sad
Fallout 3 is insane.
ZuneLover2.0
Oh you mad cuz i'm stylin on you!
« Reply #5 on: December 31, 2008, 03:27:33 AM »
it happened to me, i was listening to babyface- when can i see you again...lol oh the irony...
Gifted1
« Reply #6 on: December 31, 2008, 03:30:51 AM »
Is there an article or a thread somewhere were we can read about this "bug"? So your 30GB doesnt work anymore?
FeartheTurtle
« Reply #7 on: December 31, 2008, 03:34:22 AM »
ok guys wtf.... I left it on my zune home, set a sleep timer and playlist going woke up to find my zune unresponsive.
Its like someone killed our zunes.
ZuneLover2.0
« Reply #8 on: December 31, 2008, 03:34:48 AM »
source?
Murderface
« Reply #9 on: December 31, 2008, 03:53:36 AM »
Two seconds... it's on Facepunch.
Possibly a troll... but just to be safe.
*Edit
Can't find source, I think a biased mod deleted it.
Sorry guys...
But, the less power it has, the less HDD wear.. so let it die.
« Last Edit: December 31, 2008, 03:58:16 AM by Murderface » Logged
Gifted1
« Reply #10 on: December 31, 2008, 03:56:30 AM »
Ok so I was reading on Zune.net and apparently this has happened to people even if they didnt plug it up to the computer or have wireless on. It happened to everyone at the same time. This really sucks. And I have to take a 2 hour train ride tomorrow and will be pissed if I don't have something to listen to. Makes me wish I had my ipod as backup.
Ok, and I let my battery drain and I tried charging it again to see if it would work and I get the same problem. Grrr.
Murderface
« Reply #11 on: December 31, 2008, 04:03:55 AM »
Guys... I've been having problems with my Zune since I upgraded t to 3.0...
I've had this same problem happen before... but not permanently.
Basically, I think it could be that M$ unintentionally bricked the 30s when they installed the clock.
A sort of timebomb effect, if you will.
GamerX
« Reply #12 on: December 31, 2008, 04:51:18 AM »
is this only happening to zune 30
Tom
« Reply #13 on: December 31, 2008, 04:58:13 AM »
Wow, same thing just happened to me couple of hours ago.
I was listening to a podcast on my 30, then it stopped. Look at the screen, it was rebooting, then everything just froze when the loading bar is full. Tried all the keypad combination to restart, nothing worked.
I'm letting it to drain all the battery power out and recharge it later and see if that would work. Will report back.
EDIT:
Just went to the Zune.net forums, it seems like this is happening to a lot of Zune 30s (maybe all) around the same time. Here's one possible fix, requires dissemble:
http://forums.zune.net/404026/ShowPost.aspx
« Last Edit: December 31, 2008, 05:17:39 AM by Tom » Logged
Just for the clarification: I am a Microsoft Fanboy, I will shamelessly praise their products. However, I will not bash other products produced by other companies.
Murderface
« Reply #14 on: December 31, 2008, 05:05:28 AM »
My zune charged a lil' and just went back to the same thing.
Spare the Hard drive some un-needed work man.
Unicron Social
ZuneScene
Co-Administrator
Online Online
« Reply #15 on: December 31, 2008, 05:39:29 AM »
*Edit
Sorry guys...
I can assure you one of my mods did not delete it.
Join Zunescene on Twitter: http://www.twitter.com/zunesceneforums
Morons, Incompetent morons, These people are morons, La di di d
Principessakika
« Reply #16 on: December 31, 2008, 05:44:44 AM »
What can I do???
I miss my baby already and since I am a poor college student I do not have the funds to buy another.
"I find, in being black, a thing of beauty: a joy; a strength; a secret cup of gladness."-Ossie Davis
Loomies
« Reply #17 on: December 31, 2008, 05:47:59 AM »
Yeah...has microsoft said anything about this? This is a reallly serious issue and will get worst tomorrow as people sync their zunes in the morning. I couldn't workout today without my Zune Sad  brick sucks
Pages: [1] 2 3 ... 66   Go Up
Page created in 0.09 seconds with 23 queries.
