May 24, 2013, 12:15:46 AM
Author Topic: Problems already!  (Read 796 times)
airmaxon1
« on: September 15, 2009, 02:07:30 PM »
So I installed the software, plugged in my HD and it says installing new device, then FAILED. What is up with this? I am on windows vista.
airmaxon1
« Reply #1 on: September 15, 2009, 02:31:39 PM »
So I looked into the Device Manager and the problem says, The Device cannot Start Code 10. Ideas?
airmaxon1
« Reply #2 on: September 15, 2009, 03:34:56 PM »
Problem seems to be resolved!
LoveHateMachine
Metal Head
Red Zune 120GB Owner
WWW
« Reply #3 on: September 15, 2009, 03:37:32 PM »
Could you explain what you did for future reference?
Voted Most Helpful Member 2009
Find Me On Flickr
airmaxon1
« Reply #4 on: September 15, 2009, 03:46:38 PM »
Well I had an Ipod touch before hand, and that was still installed. I removed the Ipod software and device and rebooted, Zune automatically recognized and installed!
LoveHateMachine
Metal Head
WWW
« Reply #5 on: September 15, 2009, 03:48:34 PM »
Would seem like the iTunes thing was purely coincidence and that rebooting was just needed. I had to reboot my computer 1st.
Find Me On Flickr
Baron Munchausen
Uber Nerd
Open the Gates
« Reply #6 on: September 15, 2009, 03:54:14 PM »
Yes After Iupdated the zune software.. my computer wanted to reboot.. so i let it and after it rebooted i pluged in my zune hd and rest was flawless.. now when i wiped my zune 30 (gave her that) i told her to update the zune software 1st.. she did that then she pluged in the zune 30 and the puter wouldnt see it.. took a bit then her computer wanted to reboot too..so i told her to let it reboot and after that her puter seen the zune 30 and finished with the firmware for that..
So at first if your puter does not see the Zune HD.. try rebooting it after you upgrade the zune software and that should do the trick.
airmaxon1
« Reply #7 on: September 15, 2009, 04:01:30 PM »
Nope I had already taken those steps, rebooted several times, installed and uninstalled, rebooted zune. Those all did not work, as soon as I deleted and stopped the Ipod services, then the Zune worked!
Page created in 0.247 seconds with 21 queries.
