May 25, 2013, 02:57:47 AM
Author Topic: HD radio  (Read 533 times)
PIMCO
« on: September 16, 2009, 10:10:56 AM »
It seems that when I am listening to HD radio outside I get more channnels, but when I go inside a building the HD channel disapears and I can't hear it anymore. Is anyone else having this problem?
LoveHateMachine
Metal Head
Red Zune 120GB Owner
WWW
« Reply #1 on: September 16, 2009, 10:13:23 AM »
The signal weaken as you go inside. Just like a cell phone in the back of a grocery store. Although it is odd you only get fewer channels and not drop them all. They said HD Radio is similar to Satellite radio in the fact that you don't get static and what have you if you lose signal. It just drops the station all together.
Voted Most Helpful Member 2009
Find Me On Flickr
PIMCO
« Reply #2 on: September 16, 2009, 10:24:14 AM »
You are right. It does drop and goes to regular radio. Man I wish I was able to listen to it here at work(it's a big building)
Ray50
« Reply #3 on: September 17, 2009, 10:06:49 AM »
I assume the earphone cord is the antenna? If so try an earphone extension cord and see if that helps. In fact I will try that myself tonight (I have a 6' cord) to see if I can pull in more then 2 or 3 stations.
ab5000
« Reply #4 on: September 17, 2009, 04:03:38 PM »
One thing to keep in mind - is that it won't drop the station - but will switch to analog.  I'm not sure what the signal strength needs to be keep the HD going versus simply analog.
Page created in 0.14 seconds with 21 queries.
