metal_head_3767
« on: December 25, 2006, 08:40:53 PM » |
I wrote this guide on how to convert DVDs to the Zune using free software. Every step it detailed with screenshots. Please read it here: http://agronick.googlepages.com/convertingdvdsforzune-cost%240I would love some feedback.  Edit: I noticed that two other guides were made sticky. I was wondering if this one could be made sticky also. This forum is the only place I have posted the guide and it would make it much more worth the time it took to make it if it didn't sink pages into the forum.
« Last Edit: December 28, 2006, 02:10:31 PM by metal_head_3767 »
merryt
« Reply #1 on: December 25, 2006, 09:26:53 PM » |
gj
fgow55
« Reply #2 on: December 25, 2006, 10:10:14 PM » |
What is the estimated time to convert. I have been using DvD Dcrypter to rip the vob file aprox 10 minutes. Then using Super to convert to a MP4 and it is taking forever.
metal_head_3767
« Reply #3 on: December 25, 2006, 10:13:59 PM » |
Depends on a lot of things. The CPU, RAM, all the other hardware inside the computer, and the length of the movie. You actually end up doing two conversions. All in all it takes about an hour. I don't know of a way to go from VOB right to WMV.
« Last Edit: December 25, 2006, 10:18:25 PM by metal_head_3767 »
fgow55
« Reply #4 on: December 25, 2006, 10:20:19 PM » |
Ok
I have 3.2 Dual Core, with 2 Gigs of ram, the movie is an hour and 4 minutes long. It is not taking me very much time to rip the DVD to my drive but super is taking roughly 3 hours to convert it to the MP4. I checked and folks are say it should be about an hour.
metal_head_3767
« Reply #5 on: December 25, 2006, 10:23:05 PM » |
Try this method and see if it works better.
fgow55
« Reply #6 on: December 25, 2006, 10:29:15 PM » |
Will do Boss I will get back to you in the morning.
metal_head_3767
« Reply #7 on: December 25, 2006, 10:40:02 PM » |
I just reread your post. Yea way shorter then 3 hours. I did everything in less then an hour. VOB to AVI took half an hour. AVI to WMV took another half an hour.
I have a overclocked Athlon 4000+ and 2 gigs of ram.
fgow55
« Reply #8 on: December 25, 2006, 10:46:25 PM » |
Odly right after I made that post Super had an error, I went in and played the file and it worked fine, moved it to the zune software an it is converting as I type, should be less than 15 minutes to convert in the zune software total time should be aprox 1.5 hours now. I did have a typo in my above post the move is 1 hour 55 minutes.
fgow55
« Reply #9 on: December 25, 2006, 10:54:08 PM » |
In the morning I will rip a few other dvd's. I am sure that your way will be much faster.
aj708
« Reply #10 on: December 26, 2006, 01:18:14 AM » |
i m stock in step 8. When i click save avi, and save it, and then the compression window pops out, the only options i have are no compression, vp60 profile, vp61 advanced profile, and full frames. MPEG-4 is not listed. can someone plaese help me.
aj708
« Reply #11 on: December 26, 2006, 10:06:58 AM » |
never mind, i figured it out
metal_head_3767
« Reply #12 on: December 26, 2006, 10:13:45 AM » |
Was it listed or did you need to download the codec? If it was not listed I'll add a link to a codec pack. I just thought that since it is a microsoft codec it was included in Windows.
airmaxon1
« Reply #13 on: December 26, 2006, 12:29:25 PM » |
absolutely awesome write up, and great way to get DVD or any kind of video format to WMV. THANKS METAL!!!
tkrambo11
Offline
« Reply #14 on: December 26, 2006, 02:30:15 PM » |
good stuff dude i finally got it to work awesome stuff
aj708
« Reply #15 on: December 26, 2006, 05:30:46 PM » |
thanks for posting this, it really helped alot
madlib
Offline
« Reply #16 on: December 26, 2006, 08:48:47 PM » |
5 star post! thanks a million, is there a way to cut up a dvd with many different episodes?
« Last Edit: December 26, 2006, 11:53:32 PM by madlib »
fgow55
« Reply #17 on: December 27, 2006, 09:33:44 AM » |
This method work like a charm, takes about and hour and half but it sync very nicely.
Good job and great post
