September 10, 2010, 11:48:10 AM
Pages: 1 ... 6 7 [8]   Go Down
Author Topic: Convert DVDs to the Zune for FREE! Complete guide with screenshots!  (Read 23722 times)
metal_head_3767
Complete zunescene addict
« Reply #126 on: April 24, 2007, 09:07:42 PM »
Did you install the microsoft codec and do step 8.
rikkuluverx2
« Reply #127 on: November 28, 2007, 07:19:43 PM »
this process works....EXCELLENT! this is the kinda converter ive been looking for, thank you metal_head_3767, but i do i have a question, i have recently converted the movie final fantasy VII: advent children, and the audio clip came out as japanese, is there a way to add subtitles?
« Last Edit: November 28, 2007, 09:24:00 PM by rikkuluverx2 » Logged
sorwah
« Reply #128 on: November 28, 2007, 09:36:32 PM »
Is there any way to change the 4:3 aspect forced ratio? My original is a 16:9. The preview images show the black bars, but the compressed file has the height pulled up to match the 240 height. Typically I put it in Encode360 and E360 will leave the aspect ratio, however this specific file is the first time it's crashed once starting the encode. I need the resolution set to 320x184.
« Last Edit: November 28, 2007, 09:42:55 PM by sorwah » Logged
PandaBear
« Reply #129 on: December 02, 2007, 11:26:28 PM »
this also worked great for me!!!!!
Do i have to go through all these settings for every movie?Huh?
alake55407
« Reply #130 on: December 04, 2007, 02:51:06 PM »
I've tried installing the microsoft codec pack multiple times but I keep getting a message that it didn't install correctly and there are no compression choices coming up. I'm running Vista so I'm not sure if that has anything to do with it. I did install some Vista Codec Pack (not from microsoft) I found online and WMV9 came up as a compression choice. I'm trying that right now as I'm typing. I just got the Zune in the mail an hour or so ago so it's just charging up. Another choice was Divx Mpeg-4 but I wasn't sure if that could be a correct choice. Any insight would be appreciated. Thanks.
gjw
Online Online
« Reply #131 on: December 04, 2007, 02:57:19 PM »
When you select "Video for broadband 512 Kbps" in Movie Maker, it forces the 4x3 aspect ratio.
Somewhere in Movie Maker is the ability to edit the profiles or create a custom profile so you'd want to copy all of the settings from the "Video for broadband 512 Kbps" profile except make the resolution 320x184.
Always remember.......
Grunts (newbies) aren't necessarily stupid.
Sovereign Rulers (veterans) aren't necessarily knowledgeable.
Want to erase your Zune?  Click here:  http://support.microsoft.com/kb/926917/
Want to format your Zune?  Click here: http://support.microsoft.com/kb/927001/
Album Art problems?  Click here: http://www.zunescene.mobi/forums/index.php?topic=44784.0
Zune software crashes?  Click here: http://www.zunescene.mobi/forums/index.php?topic=25730.msg516645#msg516645
metal_head_3767
« Reply #132 on: February 12, 2008, 08:58:15 AM »
Divx won't work.  You might need the .net framework or something like that.  Just make sure you get the WMV codec.  Let us know how it works out.
rollingface
Woo!
« Reply #133 on: February 14, 2008, 02:15:38 PM »
Man, When I wrote a guide, I thought it was good. This blows it out of the water. Thank yoooouuu!
This is a pretty efficient process.
h8uthemost
« Reply #134 on: February 17, 2008, 10:03:51 PM »
This is a great tut metal_head. I've ran into a problem though.
Everything went fine up until Windows Movie Maker. When I drag and drop the two files into movie maker, and go to File, there is no option for Save Movie File.
Then options I have are:
New Project
Open Project
Save Project
Save Project As...
Capture Video
Import into Collections
Properties
Exit
I have no Save Movie File. And when I click Save Project As, I don't get the window that shows in your tut that I'm suppose to get if I clicked Save Movie File.
Any ideas? Great tutorial though. Thank you.
EDIT: Nevermind. I had to select both of the files, then Right click and press Add to Timeline. Now the Save Movie File option shows up.
« Last Edit: February 17, 2008, 10:08:46 PM by h8uthemost » Logged
matthudd
« Reply #135 on: February 19, 2008, 07:30:56 PM »
cucusoft batch connverter lets you choose chapters singely off your dvd Smiley
carver
« Reply #136 on: February 19, 2008, 07:36:48 PM »
...but it costs $30.
coffeeaddictnova
« Reply #137 on: February 19, 2008, 08:25:29 PM »
Is this tutorial exclusive for Zune 30GB? Or does it also works on Zune 80GB?
bvtiger09
Ruler of Zunes
« Reply #138 on: February 21, 2008, 04:21:10 PM »
Should work for 80GB.
Pages: 1 ... 6 7 [8]   Go Up
Page created in 0.198 seconds with 20 queries.
