EyeBaller
« Reply #18 on: December 29, 2006, 01:08:45 AM » |
That's not cleaning. Install the software I said and scan with it.
kombat_911
« Reply #19 on: December 29, 2006, 01:12:46 AM » |
ha i know its not. but if i try and install it now im afraid my computer is goignt o lag or crash cuz im running iexplorer AND zune software. anymore and the comp is going to throw one of its famous comp spazzes my comp lags when i type. it lags even more when i try to backspace. lol i pressed the download button and saved a directory for it, but nothing is happening...
« Last Edit: December 29, 2006, 01:14:54 AM by kombat_911 »
EyeBaller
« Reply #20 on: December 29, 2006, 01:16:56 AM » |
Close everything. Install what I said. How many times do I have to say it?
robinhood
« Reply #21 on: December 29, 2006, 01:24:26 AM » |
weird problem I'm having. Try to encode vob. Went through the pre phrase and ended up with a 136kb file lol. Even tho the vob is way bigger then that. Have any ideas about whats up?
kombat_911
« Reply #22 on: December 29, 2006, 01:28:12 AM » |
same exact thign ahppened to me before a long time ago but with an avi file... and this also happened with windows media encoder 9
EyeBaller
« Reply #23 on: December 29, 2006, 01:30:33 AM » |
Just the pre-phase? You have to wait until the whole encode is finished. It will take some time.. maybe 1,2 or 3 hours if you're using my settings, depending on the length of your movie and the specs of your computer.
ShirubaTsubasa
Offline
So moe, I'm gonna die!
« Reply #24 on: December 29, 2006, 01:31:53 AM » |
I'm getting the problem in "Current Known Issues #2" and K-lite codec pack is crap compared to CCCP, which is the main (if not ONLY codec pack needed EVAR). If I install K-lite, it conflicts with my CCCP. Therefore, either way I'm screwed. Opinion?
I think the point is that you may just have conflicting codecs. You can try cleaning all the codecs from your system and install your preferred codec pack. I just suggested k-lite codec pack since that's what the author states on his site. Like I said in my original guide, I didn't install it either. I cleaned up all the codecs in my PC, re-installed CCCP, and running E360 now. It seems to be working now, I'll test it on a few videos. Thanks a lot EyeBaller.
  Customer: What's the difference between an iPod and an mp3 player? Me: ...
kombat_911
« Reply #25 on: December 29, 2006, 01:32:32 AM » |
Just the pre-phase? You have to wait until the whole encode is finished. It will take some time.. maybe 1,2 or 3 hours if you're using my settings, depending on the length of your movie and the specs of your computer. it took my zune software 3 hours to convert a 3 and half minute mp4 video... but my mp4 converter only took my like 9 minutes with it.... so i want to avoid the zune software at all costs
EyeBaller
« Reply #26 on: December 29, 2006, 01:36:48 AM » |
Excellent, let me know how it goes. Kinda waiting it out until someone says it fully works for them! =)
kombat_911
« Reply #27 on: December 29, 2006, 01:38:52 AM » |
i woold love to test it out for ya but when i click download and save nothing happened!
EyeBaller
« Reply #28 on: December 29, 2006, 01:40:06 AM » |
I can't help you anymore. The original guide should work for everyone. You have computer problems. Good luck getting anything to work.
kombat_911
« Reply #29 on: December 29, 2006, 01:41:23 AM » |
I can't help you anymore. The original guide should work for everyone. You have computer problems. Good luck getting anything to work. LoL! ok, well i guess i can check out that avg thing u were talkin about now. does it hinder start up time?
robinhood
« Reply #30 on: December 29, 2006, 01:44:23 AM » |
Just the pre-phase? You have to wait until the whole encode is finished. It will take some time.. maybe 1,2 or 3 hours if you're using my settings, depending on the length of your movie and the specs of your computer. ha It finished with that. It even said encoding finished
kombat_911
« Reply #31 on: December 29, 2006, 01:47:43 AM » |
i clicked download and save again. its dowloading now  dial-up is a b!tch:(
EyeBaller
« Reply #32 on: December 29, 2006, 01:51:42 AM » |
You might have an encoder problem. You installed everything right? Windows media encoder etc.. Clean install of codec pack?
metal_head_3767
« Reply #33 on: December 29, 2006, 01:54:22 AM » |
This is gay. I made my guide way before this one and eyeballer knew this. Then he makes his own and makes it a sticky. Just because I didn't use Encode 360 because it is COMPLETLY BETA and UNSTABLE. It did not work for me and it does not work for many other people. If encode 360 doesn't work for you use the guide in my sig.
« Last Edit: December 29, 2006, 02:00:41 AM by metal_head_3767 »
kombat_911
« Reply #34 on: December 29, 2006, 02:02:20 AM » |
This is gay this might sound mean but i kinda laughed out how random that was
EyeBaller
« Reply #35 on: December 29, 2006, 02:03:08 AM » |
I didn't say anything about your guide, I know you made yours first, and you did a good job. The advantage of my guide is that the quality is consistently better, and there's an automation process you can set up for non-dvd conversions. People can choose which guide they prefer.
